okay i had a 100kw small port motor 16valve na its farked!!!!
so was considering rebuilding the block with gze pistons due to it already being
a gze block
so do i have to modify the loom? my loom has an extra plug near the throttle body anyone know what this would be?
it looks like an injecter plug :blink: just curious as to what it should be plugged into lol
computer is a power fc which will run it so thats not an issue.
any links that is going from a 4age to 4agze would be great i can read them lol
but most come up as 4ac-4agze etc <_<
i have found links about sc14 charger upgrades so thats fine lol
sorry if I'm dumb and can't find em but really i can't lol
new question
I have the following can you please help me with
the shopping list for a 4agte setup and what you reccommand in turbo selection.
it is a daily driver but will be used for track drift as well.
i have-
4agze block being rebuilt soon. (lower compression piston to be used)
ae101/ae111 crank & rods (was already in the worked 4age :blink: )
smallport head port,polished and upgraded shims.
rwd intake manifold with adapter
hks 272 & 288 cams
adjustable cam gears
trd head gasket unknown thickness so will get new one.
2rwd engines for bits.
4age smallport loom plugged into a power fc full replacement computer. (will run turbo setup)
t50 prolly upgrade later as it wont last hehehe
excedy heavy duty clutch
so can you please let me know what else i should go shopping for?
i've figured these i will need lol-
turbo
manifold
injecters
oil cooler (for drift purposes)
new trd gasket
intercooler
bov (recirculating)
remove dizzy? or not? to install crank angle?
just wondering what you may have used and have found problems with?
or conversion issues etc
you can pm if you like to.i have started to read members rides but
I'm a slow reader <_<
thanks guys
