Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 42
Thread: RT142 Suspension Options
    Veteran keiichi's Avatar
    Zac
    Sunnybanku
    <div class='quotetop'>QUOTE (Steery @ Sep 4 2008, 03:31 PM) </div>well thing is... s13 suspension is probobly easier... have you ever tried changing inserts? commo front inserts will need to be ground down around the top of the gas housing aswell a bit to fit the cap nut on when fitting the inserts inside your rona strut. theres no way around this.
    Senior Member xsoarerx's Avatar
    Logan City
    <div class='quotetop'>QUOTE (japlish @ Sep 4 2008, 11:14 AM) </div>HEY, that looks farmilar those rims look sweet as on the front! please find a matching set
    members ride on auszoku!!!
    sorry for off topic.
    Veteran bigm's Avatar
    Gold Coast
    they are pretty stiff springs so i recon they could be about right..
    if your keen at $150 including postage, then i can get swaybars
    haha
    pm me
    Zac
    Sunnybanku
    <div class='quotetop'>QUOTE (bigm @ Sep 4 2008, 04:56 PM) </div>thats a pretty good deal... whats the millimeter rating on them?
    Josh
    South Australia
    if keiichi says they will fit then im keen as.
    super super lows should dump the car a bit, about an inch'ish shouldnt they?
    cheers.
    Gold Coast
    not to sure to be honest,
    they are from my old commodore ute so i didnt care. ahah
    they were stiffer than stock thats all i know.
    i also have some good front struts (can take the tube out) and rear commodore ute shocks in good nic ahaha, if ur interested they are here.
    send me a PM if ur interested
    Zac
    Sunnybanku
    <div class='quotetop'>QUOTE (bigm @ Sep 7 2008, 07:15 PM) </div>ah wait you said VS... hmm dont think they will fit. for some reason i thought you were talking about sway bars to fit before
    Josh
    South Australia
    keiichi the kyb excel g's you had in your rona, what car were they meant for, or out of originally?
    and were you using ra65 springs in the front end?
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    he had s13 coilovers in the fornt end and sierra sports ryders with au springs in the back
    FTP.
    Josh
    South Australia
    my question wasnt referring to his coilovers.
  1. options rt142 corona avante diff??
    By GHETTOKE70 in forum Technical - Questions
    Last Post: 24th July 2012, 11:11 PM
  2. rt142 related stuff, mostly suspension related
    By claw in forum Technical - Questions
    Last Post: 1st May 2012, 09:14 AM
  3. ke70 drift suspension options???/
    By chickpea in forum Technical - Questions
    Last Post: 28th March 2010, 01:51 PM
  4. Engine Build - Valve Options - Bearing Options - Head Gasket
    By hitoriko in forum Technical - Questions
    Last Post: 19th September 2009, 05:59 PM
