Results 1 to 8 of 8
Thread: Silvertop 20v cams
    hey guys, been having a thought about cams for my ST, atm its pretty much stock internaly with just quads, razorback ecu, fuel pump and exhaust.
    got a quote today for some Ivan tigh cams which were 920 for some made up in what ever i want
    was thinkin of going with 272 and about 9mm lift
    just curious as to how these will go on the motor,
    i will be doin a bit of drift and a bit of hill climb.
    Drift skills? i thought buying an import was all you needed? well..... im screwed
    Banzai parts garage
    Action tyres southport
    Elite rthy's Avatar
    Leo
    Tulla
    well I have been quoted $350 for a pair of cams with 9.5mm of lift and 270 degrees of duration so it sounds really steep in price, as for how the engine will run I have no idea
    30kw club
    Veteran slydar's Avatar
    Dimitri
    dont think so, $350 each maybe.
    16v cams are always cheaper and the cheapest you can get them for is about around $400 a pair wholesale.
    maybe youre right sam, if you are, id love to know where you got that quote!
    78's
    gunbz-r
    I'm not sure what company it is, it's in qld, I used to get cams, valves, springs and retainers, for under $1500, and good quality too
    Senior Member Vezza's Avatar
    Vesley
    Geelong
    Would probably do good to change springs as well, although 9mm lift isn't too wild.
    Elite rthy's Avatar
    Leo
    Tulla
    I better check up on it, maybe I made a really dumb mistake and thought he was talking about a pair the whole time instead of a single. It was either clive or wade cams. I will make a post here when I find out (if I remember)
    30kw club
    Jonathan
    Camshafts... is the only thing I havn't bought yet. Will get the car running first.
    My two options are:
    TODA, easy to get. There is a dealer in Australia, but often cheaper if you have Japan connections.
    Kelford in NewZealand.
    Both have a few different grinds to choose, and both sell valve springs to suit.
    gunbz-r
    <div class='quotetop'>QUOTE (Jonny Rochester @ Sep 8 2008, 11:55 AM) </div>i brought my 20v cam's from kelford i emailed them heaps of times and got lots of good feed back, i ended up choosing the "rally" style grind but on different center lines because i'm going turbo, i didnt want anything wild, the tech department knows alot and have from my understanding built and worked with 20v's alot
  1. Replies: 6
    Last Post: 12th September 2012, 10:01 AM
  2. [PERTH] 20v Silvertop with ECU and loom, other 20v things for sale.
    By quadeyquade in forum Car Parts For Sale
    Last Post: 12th August 2012, 10:00 PM
  3. 20V silvertop
    By sr20det in forum Technical - Questions
    Last Post: 23rd May 2008, 01:57 AM
  4. silvertop 20v
    By spoon in forum Car Parts For Sale
    Last Post: 19th April 2008, 05:07 PM
  5. silvertop 20v or blacktop 20v
    By Cj_sullivan in forum General Topics (No Technical Questions)
    Last Post: 6th September 2006, 12:42 PM
