Results 1 to 7 of 7
Thread: Has anyone used any of the following..
    Just looking for some details on how these go, thanks guys
    Veteran slide86's Avatar
    Huw
    Hills
    just buy an aftermarket ecu
    it will be much easier to install and tune, with everything in one module
    Troy
    Baulkham hills
    ..give them a try and let us know.
    I agree it looks like to too much stuffing around, an all in one aftermarket ECU would be a much better idea but if you have the time and limited budget it might be a good project to play around with? Bugger all after sales support though I would think.
    Jun 2009
    Mal
    Qld
    Bris Nth
    The ignition one looks great if you wanted to keep standard dizzy and run a twin weber set-up.
    Im not that schooled up on the 20v conversion but it may come in handy for running the ignition for that on the cheap too.
    <div class='quotetop'>QUOTE (HighLife @ Sep 8 2008, 09:26 AM) </div>
    I know...
    i would prefer an aftermarket computer i bought a suposed ems dual sport turned out to be only a ti it suits magnetic dizzys not optical like my car has. so that is a $700 paper weight..
    I dont want to spend too much then again.. then only reason i want adjustability is so i can sotp my car running so rich..
    200k's to a full tnak of fuel isnt fun
    gunbz-r
    If you spent the money and time diagnosing what is actually the issue that would be a far better outcome. You never know if you go through all the trouble of fitting all that stuff to have it not fix anything
    I know but i dont know how to diagnose the problem... besides replace parts.
    I have new o2 sensor new water temp sensor new fuel reg. Timing is set within tolerance . plugs are new leads are new. Boost is reasonable. new air filter. no cooler leaks..
    If i have to put it on a dyno to figureout my problems then i would prefer to have some adjustability rather then having to go back again..
