Results 1 to 3 of 3
Thread: Factory 4age oil pressure sender outlet on block
    zilla
    nsw
    central coast
    Hi,
    Is the oil that the factory oil pressure sender taps into on the intake or discharge side of the oil filter?
    i.e. Is it filtered oil or un filtered oil at that point?
    Looking at the diagram below I am not 100% sure, so I thought I would ask.
    Just doing the oil feed line for my 16v turbo conversion, and deciding whether to run it from my (JJR) sandwhich plate, or from where the factory oil pressure sender screws into, as Leg's old engine seemed to use.
    [attachment=30727:4agoil.gif]
    scott.
    Veteran biggo's Avatar
    Nick
    Noosa
    it is filtered oil.
    oil gets picked up then thru the oil pump into the filter (outside in, more surface area) then thru the mains.
    if you had run a sandwich plate you would be running unfiltered oil thru the turby. There are inline filters you can buy for them to work that way tho.
    zilla
    nsw
    central coast
    <div class='quotetop'>QUOTE (biggo @ Sep 10 2008, 05:54 PM) </div>
    Thanks Biggo, thought so but no harm in asking.
  1. 4AG oil pressure sender
    By nelpd96| in forum Cars or Parts Wanted
    Last Post: 15th April 2010, 07:03 AM
  2. oil pressure sender questions
    By Fozz in forum Technical - Questions
    Last Post: 11th May 2009, 10:43 PM
  3. oil pressure sender
    By h1_roll4 in forum Cars or Parts Wanted
    Last Post: 14th August 2008, 08:21 PM
  4. Factory Oil Press Sender
    By Dish in forum Technical - Questions
    Last Post: 4th January 2008, 11:54 PM
  5. WTB: 4age oil pressure sender
    By d-shiznit in forum Cars or Parts Wanted
    Last Post: 3rd May 2007, 12:51 AM
