Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: F-Series Tarago Diff Models and Years?
  1. #11
    Ok
    Seamus
    Milton
    YR21 also had an F-series, 4.1:1 open diff
    I cant remember what year model, i just remember it was def YR21
  2. #12
    Mt Macedon
    It sounds like E vs F isn't just 20 vs 21 vs 22 in the Taragos.
    It could well be as suggested above that the EFI motors (4YE) got an F because of their axle bending torque, while the carbed motors got Es since they couldn't twist a pretzel. The YR22 I stripped was EFI and F.
  3. #13
    Shaun
    Capalaba
    sorry guys a bit off topic but do lite-ace vans come with lsd rear ends im lookin for something not as wide as t-series etc to fit an escort..
    any help would be great cheers
  4. #14
    Gone
    Joel
    Picton
    im not sure whats shorter but all of the above are longer then a T series.. u prolly just have to get one shortened..
    and like a said before im pretty sure u should disregard the chasis code and take note of weather its EFI or carb engine.. like has been said just going with Yr20 21 or 22 doesnt mean its holding an F series or an E series... im not sure if the housings are different either.. i can take a snap of my F series tomorrrow and post a pic.. if someone can slap up a pic of an E series.
  5. #15
    Anthony
    theyre not leaf, theyre all coil rear. lite ace is leaf. YR20 and 21 is definitely E series and only YR22 Tarago and later YR22 Spacia is F series. 4.1 and 4.3 is readily available depending on whether theyre auto and manual and centre only is same as later 30 series wombat tarago (these are wider and 5 stud).
  6. #16
    Veteran Dom86's Avatar
    Dom
    Balga
    That is good
    thanks
    The Track Car Build: Indigo
    A Heap Of For Sale: The Heap
  7. #17
    Senior Member stouty's Avatar
    Leigh
    Forster
    You can use the axels and centre from E seies and put it in a T-18 housing to save having to change mounts. I found this out after pulling apart my T-18 diff to put in LSD and change ratio. Had been done by previous owner.
    You need to grind 5mm over all from the edge of the T-18 diff housing case so the centre form the E series will fit in. Then you need to drill out the holes on the E series diff case a size larger. Will fit in no problems and the axels are a bit thicker at the ends near the teeth on the E series.
    Grip TE72
    http://www.ae86drivingclub.com.au/fo...read.php?t=276
    AJPS for all you Toyota goodies
  8. #18
    okay bit confused from that, but i got the diff today and going to strip and clean it down tommorow so ill take some pics of it, the diff came from a 1984 "carby" tarago so it will be a e-series but ill find the code so i know what ration it has, but have found that 84 models did cross over to EFI that year so as previously mentioned the e-series diff crosses over to f at that stage
  9. #19
    Dom
    Balga
    only prob with the e series is you can't get a LSD center for it.
    Not a prob if you just want to weld the centre or do the mods mentioned above though...
  10. #20
    yea just locker for me, stripped both diffs down today and dropping the housings off to final drive to have the mounts cut off and welded on, gotta take some pics and measurements, my pinion and crown wheel are completley stuffed theres about 10 teeth that have completley shorn off so will look good
  1. does anyone know the diffrence in the ae86 models and years
    By enzo in forum General Topics (No Technical Questions)
    Last Post: 2nd May 2012, 02:05 AM
  2. F series DIFF out of a Tarago EFI van
    By sumfancyname in forum Car Parts For Sale
    Last Post: 26th April 2011, 10:47 AM
  3. Tarago Diff- F Series 4.3 ratio
    By Cerby86 in forum Car Parts For Sale
    Last Post: 12th November 2010, 04:27 PM
  4. Wat LSD goes into a F series Tarago diff?
    By Dongaz in forum Technical - Questions
    Last Post: 1st July 2009, 10:43 AM
  5. What is a YR22 Tarago F-Series Diff worth?
    By Golberg in forum General Topics (No Technical Questions)
    Last Post: 27th May 2009, 11:46 AM
