Results 1 to 4 of 4
Thread: agz/te spark plugs
    Member slidin 86's Avatar
    Smithfield
    Ok people i am unsure as to what plug (e.g. gappin and heat range) i should use in my 4agte. Its and smallport block with a bigport head running 15psi. Now if it has a bigport head should i run the bigport plugs or should i run the smallport plugs coz of the block
    Thanks,
    Ben.
    P.S. i did search but there was nothing about different heads on different blocks.
    Ok
    Seamus
    Milton
    the more power you make, the 'cooler' (higher number!) the plug you need
    i went to one of the jap-part dealers, and eventually used some greddy plugs that were "1 point" colder than normal, things ran better (but i was running a fair wack of boost)
    i'd suggest start at stock plugs, and work your way up
    gap .. same deal
    ^ Clicky clicky!
    Jonathan
    The 4A-GE is originaly speced with platinum plugs. It is cheaper, and maybe better to just use normal copper plugs. Or Denso U plugs, or NGK Y plugs, which are just copper with an extra edge.
    Do not use irridium unless your cold start and normal running has spot on fuel mixtures at all times. A slight rich condition will blacken the plug in no time and you will get a misfire, more so with turbo.
    For turbo, close the gap to 0.7 or 0.8mm.
    Go one step colder if the car is driven hard. A plug that is too cold will get build up, because at the correct temp the plug is ment to be self cleaning.
    i would prob run a set of ngk bkr6e or bkr5e and then just gap them down to 0.7 / 0.8
  1. 4agze/te no spark :( I need help fellas!
    By armc89 in forum Technical - Questions
    Last Post: 14th April 2011, 05:03 PM
  2. spark plugs
    By wntdae86 in forum Technical - Questions
    Last Post: 14th June 2010, 11:34 AM
  3. Spark plugs
    By Figgy in forum Technical - Questions
    Last Post: 21st April 2010, 10:20 PM
  4. Spark Plugs
    By stouty in forum Technical - Questions
    Last Post: 22nd November 2007, 05:46 PM
  5. what spark plugs do you use??
    By jeenyus in forum General Topics (No Technical Questions)
    Last Post: 20th April 2006, 12:12 PM
