Results 1 to 7 of 7
Thread: Shock absorbers
    Senior Member Intense's Avatar
    Aaron
    Ok so I've got AJPS 6kg/mm front and 4.5kg/mm springs in my car and the shocks on the back are kyb excel g, not sure what the fronts are but I'd assume they are the same.
    When I go over bumps and stuff it's really rough and feels like the car isn't absorbing them at all. I went in my mates chaser and it soaks up the bumps really well. Now the two cars have totally different susepension setups, his being double wish bone all round with irs on the back and coilovers all round.
    So what I want to know is, does your car actually soak up the bumps? What shocks are you using and what do you recommend? What price am I looking at for a decent set of shocks?
    Veteran slydar's Avatar
    Dimitri
    decent shocks are about $400-550 a pair for front inserts, rear shocks are generally a little cheaper.
    from what youre saying, and the rates youve chosen, maybe you should try bilsteins?
    excel g's are a high quality japanese made replacement shock, with slightly firmer dampening than stock.
    still, theyre always going to be borderline, even with your "soft" by ae86 enthusiasts standards spring rates... alot of knowledgeable people would still say thats over sprung.. And definitely no match for a purpose built coil over system, where the shock is valved to suit the spring perfectly (or close to).
    pretty much the unfortunate reality is i think your just expecting too much, out of what can only be termed a budget set up.
    78's
    Mar 2006
    so excel g's are good for lowed springs?...
    i read about them and they seem pretty average, my mate bought some kybs for his 92rolla and its feels like brand new stock shocks, no performance wise....or maybe its just me
    Aaron
    I'm just finding the car to be excessively bumpy. To get a real good idea I'd have to go for a ride in someone else's ae86 to give me something to compare to I guess. For all I know my shocks might even be blown. I'll get it looked at and see what I can do
    Veteran bigm's Avatar
    Gold Coast
    the best way to test if ur shocks are blown is to push down hard on the car above the wheel. if the car bounces back and stops at the top(or has a 2nd shorter movment) they are probably fine.
    if you push down and they keep bouncing slowly getting smaller they are probably shagged
    Veteran Konakid's Avatar
    Henry
    Eastern
    I run Excel G short strokes with 8 and 6, and while somewhat under damped they still do an admirable job.
    When i had 6 and 4.5 the car was much softer and more suited to the Excel G's, not really that uncomfortable though, easily liveable day to day.
    You simply can't compare the dated suspension of the 86 with that of the chaser, its comparing apples to oranges. For some good shocks at a decent price id go TRD Blues for around 1000 a set. (they were until our dollar shat itself anyway)
    Dave
    <div class='quotetop'>QUOTE (KonaKid @ Sep 21 2008, 07:11 PM) </div>yeah you have to remmeber this
    much of the larger cars, chasers/skylnes even s13s are much heavier than these poor ol corollas
    i had a similar experience in a mates R32, its got apparent good "drift" suspension, so pretty stiff. i noticed in car parks i could still feel the suspension compressing alot more than my poor ke70 (8kg and over damped shocks in front, 6kg and normal short stroke shocks in rear)
    its just to do with the weight these bigger cars to throw around.
    as for your shocks, buy some adjustable ones! then you can fiddle for hours till you get it right (wish my front shocks were adjustable...)
    - Blaise Pascal
  1. KYB AGX Shock Absorbers and accessories
    By Anthony in forum Kaizen Garage
    Last Post: 15th November 2012, 08:57 AM
  2. GAB Shock Absorbers KE70 / AE86
    By Fusion in forum Car Parts For Sale
    Last Post: 23rd February 2009, 10:56 PM
  3. Koni High Performance Shock Absorbers!
    By gslrallysport in forum GSL Rallysport
    Last Post: 15th February 2009, 07:54 PM
  4. re valving shock absorbers
    By james86 in forum Technical - Questions
    Last Post: 5th September 2008, 06:48 PM
  5. Shock Absorbers
    By lowau in forum Technical - Questions
    Last Post: 11th April 2006, 12:34 PM
