Results 1 to 7 of 7
Thread: AE86 Steering arms onto XT130 struts
    Senior Member sr_rolla's Avatar
    beau
    Bathurst
    Do they fit? Does anybody know for 100% certain weather or not AE86 steering arms fit onto XT130 corona struts?
    If nobody knows for sure, is there anybody in sydney with a spare set of AE86 arms lying around that is willing to let me try them on my struts?
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    yes mate they will fit
    Veteran slydar's Avatar
    Dimitri
    fit for sure. set up is in my car under my house.
    another thing i might point out man..
    have a look at the caliper bracket bolt spacing on the xt strut.. and then check out the wilwood spacing
    78's
    Jonathan
    The bolt pattern is right. The AE86 arms do fit the XT130 struts. But the offset of the AE86 arms is different to the XT130 arms. There is an issue if you are running the HiLuX 4wd brakes (with XT130 struts and AE86 arms), as the disk will hit or come too close to the lower control arm with this setup. If you are running the HiLux 4spot brakes, you may have to use the XT130 or RA23 arms (and have the shortened if you need that).
    Senior Member Ksevn-T's Avatar
    They fit!
    like a glove!
    数独のガレージ "Sudoku Garage" <3<3<3
    Dimitri
    <div class='quotetop'>QUOTE (Jonny Rochester @ Sep 22 2008, 05:56 PM) </div>can imagine it might. i have ra60 discs, and ive only got about 5mm clearance disc to outside of lca, using 86 steering knuckles.
    78's
    beau
    Bathurst
    thanks for all the replies
    SLYDAR about that bolt spacing, 90mm ish, same as a lot of aftermarket calipers hey
  1. WTB. xt130 control arms,P/S ae 86 steering arms
    By sleepy in forum Cars or Parts Wanted
    Last Post: 5th September 2011, 09:38 PM
  2. xt130 steering arms, ae86 lca's
    By 15LIDE in forum Car Parts For Sale
    Last Post: 15th June 2010, 09:36 PM
  3. wanted ae86 struts and steering arms, strut brace
    By darkon in forum Cars or Parts Wanted
    Last Post: 11th August 2008, 02:26 PM
  4. xt130 lca's and ae86 steering arms
    By SON57A in forum Cars or Parts Wanted
    Last Post: 24th July 2008, 12:39 AM
  5. FS ae86 crossmember struts steering arms ect
    By ar86 in forum Car Parts For Sale
    Last Post: 20th May 2007, 01:59 AM
