Withdrawn from sale...
Turns out these are not what I was told they were...I am not prepared to sell something that
has dodgy specs....
Regards
Scott
has dodgy specs....
Regards
Scott
sounds interesting.
what is it youre not 100% sure about? the condition? or the specs?
78's
<div class='quotetop'>QUOTE (slydar @ Sep 22 2008, 09:20 PM) </div>Condition is fine...I need to ring Tighe to check the specs...(Grind Numbers stamped on end)
FIRST POST EDITED...
ok.. the ex' is bigger than the intake though, are you sure? seems at odds to convention is all. definitely considering them man, but if you could double check, thatd be good![]()
78's
<div class='quotetop'>QUOTE (slydar @ Sep 23 2008, 01:26 PM) </div>That is how the cams are designed.
