I had this problem, the most likly cause is a vacuum leak.
Have you blocked off the stock fitting on the inlet manifold for the breather pipe fromthe rocker cover? these sometime become unusable when you do the cut n shut, block it off with finger, see if it makes a difference.
Also i would take your air filter/pipe of the Throttle body and stick you finger in, and block off the port at the bottom, this was why mine 'Hunted' at idle, after i blocked off the idle up/water thingy underneath.
Hope this helps bud!!![]()
