Results 1 to 6 of 6
Thread: brake master
    mark
    central coast
    hi, does anyone know if a ke70 brake master is the same as an ae86 or if you can swap them.
    thanks mark
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    <div class='quotetop'>QUOTE (enigma @ Sep 28 2008, 08:04 PM) </div>I'm reasonably certain that they are interchangeable, but only on ADM sprinters.
    Senior Member stylz's Avatar
    Art
    Melb
    what are other options as well? my brake master cylinder has shat its self and its time to replace it. is there anything i can use?
    VLNY
    Lawrence
    Wollongong
    <div class='quotetop'>QUOTE (stylz @ Sep 29 2008, 07:10 PM) </div>Rebuild it? if its just the seals inside it which have gone and the bore isn't damaged you should be able to seal kit it and it'll be like new.
    Art
    Melb
    <div class='quotetop'>QUOTE (Golberg @ Sep 29 2008, 09:18 PM) </div>ahh yea, would you happen to know the kit number and where i can purchase it from?
    i was looking at just replacing the unit and doing a straight swap so the car isnt out of action for a few days.
    but if i can get a kit for it easily enough ill just do that, hoping the bore isnt damagedbut i guess i can always try to resleeve it at work
    VLNY
    john
    nsw
    liverpool
    either sprinter or ke70 ... couldnt you just go to repco or a spare parts place and order a new brake master ... ? should be just off the shelf .
  1. Brake master's
    By Faceplant456 in forum Technical - Questions
    Last Post: 10th December 2009, 09:27 PM
  2. new brake master
    By enigma in forum Cars or Parts Wanted
    Last Post: 18th June 2009, 07:23 PM
  3. s13 brake master
    By dr1ft-pig in forum Car Parts For Sale
    Last Post: 28th August 2008, 01:09 AM
  4. Replies: 2
    Last Post: 7th March 2008, 07:43 AM
