<div class='quotetop'>QUOTE (enigma @ Sep 28 2008, 08:04 PM) </div>I'm reasonably certain that they are interchangeable, but only on ADM sprinters.
hi, does anyone know if a ke70 brake master is the same as an ae86 or if you can swap them.
thanks mark
what are other options as well? my brake master cylinder has shat its self and its time to replace it. is there anything i can use?
VLNY
<div class='quotetop'>QUOTE (stylz @ Sep 29 2008, 07:10 PM) </div>Rebuild it? if its just the seals inside it which have gone and the bore isn't damaged you should be able to seal kit it and it'll be like new.
<div class='quotetop'>QUOTE (Golberg @ Sep 29 2008, 09:18 PM) </div>ahh yea, would you happen to know the kit number and where i can purchase it from?
i was looking at just replacing the unit and doing a straight swap so the car isnt out of action for a few days.
but if i can get a kit for it easily enough ill just do that, hoping the bore isnt damagedbut i guess i can always try to resleeve it at work
VLNY
either sprinter or ke70 ... couldnt you just go to repco or a spare parts place and order a new brake master ... ? should be just off the shelf .
