Results 1 to 6 of 6
Thread: air con in a 86
    has anyone kept air con in their sprinter using the stock aus spec evaporator and lines to dash with a 20v motor?
    my car has all the dash business but wondering what sort of air con compressor system to run?
    also looking for the parts to make it happen
    Elite rthy's Avatar
    Leo
    Tulla
    well if your lucky your original lines will fit right onto the stock 20v compressor, I even have one I am throwing out that may still work
    another option is theres a chance your original 4ac one will fit on the 20v bracket and then you just swap the pulleys, but again its an unknown
    <div class='quotetop'>QUOTE (Sam_Q @ Sep 29 2008, 10:20 PM) </div>from the looks of the diagrams 20v runs a v belt
    16v a flat belt so wont work
    plus i have NO COMPRESSOR AT THE MOMENT
    if you have any air con stuff you dont want i am happy to pay postage if you want to send it.
    Elite rthy's Avatar
    Leo
    Tulla
    well I thought it would work if the pulleys where swapped hence converting the 4ac compressor to a multirib drive. Do you have the appropriate brack to mount the compressor right now?
    I am happy to post and $20 should make it happen, but lets talk about that later
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I was planning on running a stock AE92 aircon compressor on its original bracket on my small port 4AGE. After fitting it up though it was sitting right on the swaybar. I think you'll find a similar story using a stock 20v bracket.
    What I did to solve that problem was to buy a JDM AE86 compressor and bracket. I see no reason as to why you couldn't do the same and I think you'll find you're 20v has a 5 rib belt like every other 4AGE. You'll need to use a JDM AE86 crank pulley though to run the JDM aircon compressor.
    interesting stuff.....
    ill have to look into it
  1. Air Con. how to remove front air-con cooler safely
    By Ade_Mc in forum Technical - Questions
    Last Post: 6th March 2010, 10:05 PM
  2. WANTED AIR CON
    By dave2221 in forum Cars or Parts Wanted
    Last Post: 3rd October 2008, 11:08 AM
  3. Air con Set-up
    By Dish in forum Car Parts For Sale
    Last Post: 21st February 2008, 10:06 PM
  4. like new, air con unit
    By roger roger in forum Car Parts For Sale
    Last Post: 21st February 2008, 05:08 PM
  5. AE86 Air Con
    By 73ta22 in forum Cars or Parts Wanted
    Last Post: 26th December 2007, 04:03 AM
