I have hit a brick wall.
Been doing a 4AGE conversion in my KE70 pannel van with a T50 box. Now the engine and box are in, but when I went to bolt up the tail shaft, the length is correct HOWEVER, the "stud hole patterns" of the tail shaft end (im using an AE71 tailshaft) and the stud holes on the diff center dont line up.
I was lead to believe an AE71 tailshaft would bolt up directly to the KE diff?
Is it possible that because its a pannelvan, it uses a different diff?
What are my options? The Original KE tailshaft obviously bolts to the diff, but wont line up with the spline on the T50, so thats out of the question. Will I have to get my tailshaft modified? Or will I be able to bolt an S series center into me KE diff?
Any help at all would be greatly appreciated.
Thanks, Matt.
