Up for sale is the front suspension from the Dirty Ibis, including:
Brand new HSD HR (pillowball) coilovers with 8kg/mm springs
S13 uprights and hubs (4x114.3)
Boxed S13 lower control arms
Rose-jointed S13 caster rods with modified/strengthened chassis mounts to suit
1 pair of Z32 4-piston calipers
1 pair of brand new slotted DBA Z32 rotors (280x30mm?)
The rotors are still 5-stud so need drilling to 4x114.3
The camber tops on the coilovers are the HSD S13 ones, so you will need to either replace them with AE86 ones, or do what I did and re-drill the strut towers
Your crossmember will need to be drilled out to 14mm to take the bolts for the S13 LCAs
Asking price is $1500 for the lot. This does not include tie-rods, but from memory MA70 Supra ones are used and they are available from Repco or whatever for not much $$$
Pick-up from Sydney only
The parts will hopefully be available after this weekend.
Any question give me a call on 0416 949 751
Cheers,
Jeremy.
