none of the bolts "need" to be torqued using a torque wrench.
torque settings for what?
ok then that makes it easy, i was thinking about the bolts down the bottom, the ones to the steering arms, but if they dont need it then itll be easy
cheers mate!
I also suggest RCA's!!!!... Oh and change your wheel bearings while your at it!! like 20 dollars a corner and you have to pull the hub off anyway.
