If you widen your rim from 7.5 +2 to an 8inch rim your offset will be -3 and if you go 8.5 your offset will be -8. Correct me if im wrong but im 100% sure thats what it will be because your only changing the width
This may or may not be on topic,
but who in/around Brisbane does custom outer bands for wheels?
Reason for asking is, rims in the sizes I want are hard to find.
I've found a set of 15x7.5 +2 rims for under a grand, and If a pair were widened, to say, 8's, by just putting a wider outer band on them, that would mean approximately -10 offset, which is sweet.
And if the other pair was widened to 8.5, it would mean approximately something like -22 or -23, which I can get away with on the rear with a flair and 195's (R31 guards are pretty big).
So yeah, is there any place that does that sort of thing? And what costs would be associated?
I remember Slydar on here did something like that?
Anybody with 15x10 superlite wheels?
Keep them coming guys!
7.5 +2
8.0 -4
8.5 -11
basically if you only change the outside by 1" the offset -12.7mm, increase width by only 1/2" offset -6.3mm
would look SOMEWHAT less shit. howver 195 or 205 would look far better.... OH SHIT, i hope the JDM BOIZ didnt hear me say that![]()
hey man,i got some 13x8-13 speedstars if you wanna get a little stretch on?
has anyone have rota grids on a ke70?
16 by 8 10 offset?
hahahaha
have seen in real life looks dumb as.
Front- 14x7-5 0 camber standard control arms.. +5 castor and lip of guard is flat, the wheels line up perfectly with guard. 185/60
Rear- 14x8-14 s series dif 185/60
