Results 1 to 8 of 8
Thread: T-50 bellhousing to gearbox gasket
    Adam
    South Eastern
    Default T-50 bellhousing to gearbox gasket
    Hi all, just wanted to know if I need any gasket goop or sealant on the paper gasket located between the gearbox and bell housing on a T-50
    Cheers,
    Adam
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Nope, I've never used any.
    Andrew
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    Youll need goop around the layshaft exit. All of mine have been goop though, no paper/cork gaskets.
    Adam
    South Eastern
    assassin1000 & takai,
    i have the factory paper gasket sitting here, so not sure where or not it requires goop?
    Jul 2009
    Vic
    Shouldnt need goop. Spraying it with Hylomar is a good insurance policy though. Dont want to have to pull the gearbox again for something so minor.
    Davey & Riki-lee
    South Australia
    Seaford SA
    I have used the Toyota red sealant (for gearboxs) just to keep dust out as it doesn't have oil to seal only at the shaft
    Our introduction - Click here
    Senior Member DearmanKE's Avatar
    Alex
    Northfield
    i usually put abit of goop, (threebond is what i use) on paper gaskets but only a thin smear just to take up the imperfections in the metal as ive found if the surfaces arnt 100% smooth the paper gasket wont cut it, and if you only use a little uve got zero chance of it causing trouble.
    Formerly known as grape_moosha
    West
    Paper gasket is cheap from toyota, I photocopied mine so next time I need one I can trace it and make one.
  1. NSW: T50 gearbox with bellhousing
    By sotiros86 in forum Cars or Parts Wanted
    Last Post: 26th April 2012, 10:43 PM
  2. T-50 Bellhousing (AE86/71) or complete gearbox...
    By shelldrake in forum Cars or Parts Wanted
    Last Post: 22nd March 2011, 11:38 AM
  3. i need a ae71 T-50 Bellhousing
    By aaronke70 in forum Cars or Parts Wanted
    Last Post: 20th October 2010, 09:14 PM
  4. Not so DIY: Made a T-50 Bellhousing to W58 transmission adapter.
    By assassin10000 in forum Technical - Articles
    Last Post: 20th July 2010, 02:12 PM
  5. SA - 4A Gearbox Bellhousing
    By fusion in forum Car Parts For Sale
    Last Post: 2nd October 2008, 07:37 PM
