Results 1 to 10 of 16
Thread: How to Wire coil on plugs? 20v ST w/ Aftermarket ECU w/ 4 coil pack
    May 2011
    Jonathan
    Mitchelton
    Default How to Wire coil on plugs? 20v ST w/ Aftermarket ECU w/ 4 coil pack
    Gday, I have a 20v ST w/ microtech running x4 ignition + 4 coils and want to wire up some 1zz Coil on Plugs. Can anyone help with some info on changing my wiring or point me in the right direction pls?
    Anthony
    theres a pinout diagram I did in the coil pack info thread.
    May 2011
    Jonathan
    Mitchelton
    Apologies, I found it its available here:
    I presume the wiring is more involved than I first thought as my engine is setup with an ignitor (microtech X4), but the coils already have ignitors. My guess is that the x4 ignition needs to be deleted and new wiring done for the coils?
    May 2011
    Jonathan
    Mitchelton
    Thanx for yr help Anthony, please excuse my ignorance but I presume the ecu (Microtech) may need to have settings changed to suit the coils?
    Anthony
    No it should be fine. whatever dwell its on will suit. assuming its a "toyota" type of microtech.
    Yes you will need to get rid of the "x4". whatever trigger wires went in to it now go straight to the coils. Not too hard.
    May 2011
    Jonathan
    Mitchelton
    Awesome, thanx again for yr help
    Moderator Sam-Q's Avatar
    Endeavour Hills
    crude website that one,
    what you do is disconnect your existing ignitors and run the signal wires directly to the coilpacks. So do you need a coilpack adapter plate?
    Anthony
    haha workin the tech threads!
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    bumping up old thread as im getting the same problem but i seem to get my car started up.
    here is what i've done :
    grey/red ----> yellow ----> coilpack1 (cyl1)
    grey/black ----> orange ----> coilpack2 (cyl2)
    grey/green ----> yellow/black ----> coilpack3 (cyl3)
    grey/white ----> orange/black ----> coilpack4 (cyl4)
    AND ACCORDING TO SAMQ SITE
    pin1 ---> earth
    pin2 --->trigger
    pin3 ---> feedback? i dont know where that goes
    pin4 --->12v
    the car cranks but does not start. just cranks and pops from exhuast
    Pick up Sydney
    Pics can be sent by phone
    Emails ignored
    Texts ignored
    Private numbers ignored
    Wankers abused
    Phuoc
    Liverpool
    cant seem to get spark. do i need to access the ecu and change any setting?
    Pick up Sydney
    Emails ignored
    Texts ignored
    Wankers abused
  1. Coil Pack pin-out for Microtech on 20v
    By ArubaAE86 in forum Technical - Questions
    Last Post: 19th May 2012, 11:24 AM
  2. 2nz coil pack
    By evil86 in forum Car Parts For Sale
    Last Post: 8th January 2012, 10:10 PM
  3. FS: Full coil over for AE86/KE70, Aftermarket 4AGE ECU, Earthing kit
    By charlie_keto in forum Car Parts For Sale
    Last Post: 6th July 2010, 07:47 PM
  4. coil pack and ignitior
    By ca18ae71 in forum Cars or Parts Wanted
    Last Post: 15th June 2010, 11:07 AM
Tags for this Thread
