Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Flywheel and pressure plate 4age
  1. #11
    Senior Member Moebius's Avatar
    Christian
    Did mine for the first time on the weekend. Torque wrench only went as low as 40 so had to guestimate it.
  2. #12
    Veteran blair's Avatar
    Blair
    SEQ
    This is also my method.
  3. #13
    Veteran timbo's Avatar
    Tim?
    Wild West
    Undid mine today, if they were anywhere else on the car I would have said they were loose.
  4. #14
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    using a 1/2" wrench on a what 12-14mm nut, no need
  5. #15
    Senior Member DearmanKE's Avatar
    Alex
    Northfield
    yeah they defs dont have to be super tight, just did my 4age pressure plate and did them up with a spanner and just locked them up and tapped to give them abit more(coz the engine was spinning if i just turned it without tapping
    Formerly known as grape_moosha
  6. #16
    Mar 2011
    Ali
    Thread revival,
    Do the pressure plate bolts into the flywheel need spring washers?
    Problem being had no old bolts to go off, so rang clutch store, he said high tensile steel bolts and hardened steel washers.
    I took that as flats....Am now wondering if I should use springs as well?
    Gut feeling says yes.
    Ali
  7. #17
    Michael
    Crimebrook 2749
    if i remember correctly, the toyota ones are just a spring washer
  8. #18
    Mar 2011
    Ali
    So just springs....
    Yeah that sits with me better.
  1. Replies: 0
    Last Post: 22nd August 2010, 05:29 PM
  2. JDM bellhousing & TRD Flywheel and pressure plate
    By Gunner in forum Car Parts For Sale
    Last Post: 5th July 2009, 11:58 PM
  3. JDM 4AGE flywheel, clutch and pressure plate
    By foxtail in forum Car Parts For Sale
    Last Post: 27th June 2008, 12:12 AM
  4. 16v 4age clutch plate and pressure plate
    By driftae71 in forum Cars or Parts Wanted
    Last Post: 7th August 2007, 01:36 AM
  5. FS: 200mm exedy clutch, pressure plate, flywheel
    By aeke7086 in forum Car Parts For Sale
    Last Post: 12th March 2007, 04:00 PM
