Results 1 to 10 of 10
Thread: 7AGE 20V Spark Plug Recommendations
    Ok
    Seamus
    Milton
    Default 7AGE 20V Spark Plug Recommendations
    Sup,
    I have had some denso iridiums in my car since my car came from japan. They're starting to look fairly average, so i'd like to replace them.
    FSM says the recommended plug is a BKR6ep11
    Could i benefit from a cooler/hotter plug? Should i go iridium/platinum, or just coppers?
    I've never given half a shit about plugs before, so i welcome any suggestions. Thanks.
    ^ Clicky clicky!
    kyle
    Newport
    bkr5eya ngks tryed iridiums before some reason they seemed to foul up quicker over time
    Veteran timbo's Avatar
    Tim?
    Wild West
    Well IMO its a tough one. So far I've cooked NGK BKR5EYA, NGK BKR6EP-8 Platinum and Bosch Platinum...
    Veteran johl's Avatar
    Johl
    it is not worth paying for platinum. just change copper regularly. i have read a few articles on comparisons and the copper actually give stronger spark but just dont last as long. but in a 4age it takes about 3 seconds to change plugs unlike wrx/evo's where it is a shit job.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    run copper, unless you get iridiums cheap i wouldnt bother
    Ok
    Seamus
    Milton
    And which heat range for coppers?
    ^ Clicky clicky!
    Glenn ke_70's Avatar
    Clay
    Barossa!
    yeah the only advantage of iridium is longer life.
    just change plugs everytime you do an oil change.
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    heat range is dependent on the engines usage run a colder plug if its getting thrashed on the track and a hotter plug if its more street driven
    the dyno pull to 300rwkw
    Michael
    Crimebrook 2749
    im lead to beleive also you can run a bigger gap on iridiums (dont tell me you cant gap them)
    "cleaner" spark probs load of bs, jsut what i have heard
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    I haven't really looked into this but my mate was advised to run copper plugs on his drift car with a rb26 in it. His tuner says copper gives a better spark and also recommended to change the plugs every 5000km's
    ADM AE86 Levin
  1. WTB 4age 20v spark plug leads
    By matho in forum Cars or Parts Wanted
    Last Post: 6th July 2012, 01:31 AM
  2. FORSALE carbon fibre 20v spark plug cover $95 posted
    By ae86 drifter in forum Car Parts For Sale
    Last Post: 11th January 2011, 09:15 AM
  3. Ideal coil on plug spark plug to suit 20v
    By 4.5AG in forum Technical - Questions
    Last Post: 19th October 2010, 10:38 PM
  4. 20V Spark Plug numbers
    By race4ages in forum Technical - Questions
    Last Post: 9th October 2009, 07:18 PM
  5. 20V spark plug lead tubes compatabilty from other vehicles?
    By Sam_Q in forum Technical - Questions
    Last Post: 21st June 2008, 09:10 PM
