Basic XT130 setup:
- XT130 Struts
- XT130 Hubs
- XT130 Brakes
- XT130 Steering Arms
- AE71 strut tops.
Optional Parts:
- XT130 LCA (20mm O/A track increase and roughly -1º camber)
- Hi-Lux/Peugeot brake upgrade.
- AE86 power steering arms (More lock, but will cause rotor to foul on end of LCA. Can be solved with strategic use of a hammer)
- AE86 camber adjustable strut tops.
Process:
- Disconnect brake lines from AE71 calipers.
- Unbolt and remove entire AE71 strut assembly.
- Remove AE71 steering arms from ball joint.
- Assemble XT130 strut assembly using AE71 strut top.
- Bolt XT130 steering arms to ball joint.
- Insert new XT130 strut assembly.
- Connect brake lines (Don't forget to bleed them afterwards)
- Wind out tierods to suit longer XT130 steering arms.
- Wheel alignment.
- Done.
Obviously this is the basic run down. Replace LCA with Corona item if needed, and/or steering arms with AE86 ones for more lock. Also, would highly recommend shortening the strut and going coilovers if you choose this route. A mildly lowered car with the basic setup mentioned above will have little to no suspension travel and make for a shit handling car.
