Results 1 to 7 of 7
Thread: 4age into my ae71 spirit
    Jun 2011
    luke
    panorama
    Default 4age into my ae71 spirit
    hey
    either this weekend or the next weekend im going to start putting my 4age in
    its a 16valve bigport out of an mr2
    ive worked out that im going to use a vl fuel pump( im still not sure whether or not to use a surge tank)
    ive got my loom and computer
    and ive been told that i can still use my ae71 radiator (do i have to use a thermo fan? )
    any advice would be helpful
    thanks
    Stern but now fucked off...
    May 2005
    Nick
    Moved to tech questions forum...
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I suggest a hyundai radiator instead
    Dave
    standard ae71 radiator is fine. served me well for 3yrs of 4age ownership. pipes are on the correct side too.
    please don't use the VL high pressure pump on its own. At the very least fit the low pressure pump inside the tank (easy as, there is a tech article on rollaclub).
    and you should really put a surge tank in between the two pumps.
    that way the pump is happy, high pressure pumps do not deal well with trying to suck fuel.
    and of course 10 ppl are going to chip in and say "ive used a VL pump on its own for years and its been fine"
    but if you want a silent fuel system, and you don't want your pump to burn out over time, put a surge tank in or at least the lift pump.
    - Blaise Pascal
    I used a Vl pump without a surge tank and that, and it was bloody loud. Also noticed fuel surge at anything under 1/4 a tank too.
    I wouldn't waste your cash on a hyundai radiator either. Thermo fan is recommended for hot days and when you are stationary in traffic etc.
    Endeavour Hills
    the reason why I suggest the Hyundai radiator upgrade to people is not because of the higher cooling performance but because ae71 rads are often at an age where they are failing and if the hoses need to be changed anyway I figure it's a good time to fit a common and cheap to source radiator. Also if someone is fitting a smallport or 20V they would need to change the pump first before putting a mechanical fan on.
    Jun 2011
    luke
    panorama
    well i got the 4ac out today and cleaned up the gearbox. i reckon im sold on the idea of a surge tank (cant do any harm) and i might stick with the ae71 radiator with a thermo fan and if it starts to get a bit warmer than usual i might go for the hyundai one.
    thanks for all the advice
  1. My 4age AE71 Spirit.
    By Drift_Donkey in forum KE70 / AE71 Owners Forums
    Last Post: 8th November 2009, 07:36 PM
  2. AE71 Spirit - 4age - LSD - Grip Machine
    By LittleRedSpirit in forum KE70 / AE71 Owners Forums
    Last Post: 5th April 2009, 11:09 PM
  3. Ae71 Spirit Part out
    By import_love in forum Car Parts For Sale
    Last Post: 10th September 2008, 02:25 PM
  4. AE71 Spirit
    By 84_AE71 in forum KE70 / AE71 Owners Forums
    Last Post: 3rd July 2008, 08:12 PM
