Results 1 to 10 of 15
Thread: Leaking oil adaptor
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    Default Update; Leaking sandwich plate
    Car - AE86
    motor - 4agte
    problem - Leaking oil adaptor
    As title says I have a leaking adaptor in the side of my block to which my oil pressure sensor is attached and from which an oil line is connected to my turbo. Also there is a fitting screwed into that adaptor to be able to connect the oil line to it. Just to be clear it's not an adaptor block onto which the oil filter mounts, it's just a small adaptor in the side of the block in front of where the actual mounting point of the oil filter is.
    As often happens the adaptor and fitting are 'sweating/leaking', it's not a lot but enough to get a decent amount of oil on my fingers.
    My questions is what would be the best way to seal the thread? First thing I thought about was that white tape you use to seal the connection of water lines etc but would this withstand the heat? Otherwise something like loctite?
    Any advice is appreciated!
    ADM AE86 Levin
    Jake
    Northgate
    Maybe some sort of FIPG? Otherwise if it didn't have any type of sealant there might need to get a new one?
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    Hmm, I think FIPG is more intended to seal as a gasket. What I'm trying to do is sealing thread, dunno if it would be usefull for this as well...
    ADM AE86 Levin
    Jake
    Northgate
    Ah sorry read it the wrong way, you can get thread sealant we have it at work pretty sure its locktight band ill have a look tonight if I remember and see if its ok to use for high temp.
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    Nevermind, did some research on the loctite site and loctite 542 should work, getting some from conventrys tomorrow.
    ADM AE86 Levin
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    In addition, when disconnecting the connectors and oil line to the turbo I will get air in the line, is this a problem and if so what should I do to prevent it?
    ADM AE86 Levin
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Liquid teflon for pipe threads, instead of tape.
    Air in the line shouldn't matter... it'll just get pushed through a few seconds after starting.
    Andrew
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    Update:
    It appears that the sandwich/adaptor plate between the engine and the oilfilter is also leaking a bit.
    Is there an easiest way to fix this as it will probably be the gasket...?
    Thanks!
    ADM AE86 Levin
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Remove/disassemble & replace o-ring/gaskets.
    Andrew
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    Yeah that was what I was thinking as well but I've got no idea what brand the adaptor plate is so also no idea how the O-ring/gasket looks and where to get it...
    ADM AE86 Levin
  1. Oil adaptor block on AE101 4azge
    By Bozu in forum Technical - Questions
    Last Post: 24th May 2012, 09:49 AM
  2. t3 adaptor 20v to 16v inlet adaptor
    By 4AGENT in forum Cars or Parts Wanted
    Last Post: 13th January 2011, 12:26 PM
  3. diff leaking
    By johl in forum Technical - Questions
    Last Post: 28th February 2009, 09:25 AM
  4. Leaking Diff
    By Dave in forum Technical - Questions
    Last Post: 10th January 2009, 05:01 AM
  5. 4ac Oil pressure adaptor
    Last Post: 23rd May 2007, 01:07 PM
