Results 1 to 10 of 17
Thread: Making an ARC-style airbox.
    Ok
    Seamus
    Milton
    Default Making an ARC-style airbox.
    Yoyo.
    I'm thinking of buying a plenum etc for my 20V, and then i thought of airboxes. There aren't many off the shelf (1?? Arc only?), and it's stupidly expensive
    Which made me think i could make my own - preferably just like ARC, which has a full panel filter.
    Questions are (to those who know / have thought this through / just feel like contributing or talking shit):
    1) Half the idea of this is to keep it relatively cheap - i'm thinking of just making something that could house a VL/VN panel filter, as they are retardedly cheap for a high-flow/k&n filter. Or are there better flowing / cheaper / smarter options out there? I don't want to skimp on the performance aspect of it either
    2) Inlet from the throttle body/intake pipe would obviously come from the side - would it be best to have the filter on top of the airbox like most of the ARC units? Or would it be better elsewhere?
    As you can see, i haven't thought this through - i'm hoping you guys just spoon feed me haha
    Thanks, Seamus
    ^ Clicky clicky!
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    use a VN air box??? or do you want something nicer??? if so copy VN airbox but instead of clips use bolts and nuts
    Glenn ke_70's Avatar
    Clay
    Barossa!
    clear plastic would be sick. hard to make tho.
    still an idea
    Veteran timbo's Avatar
    Tim?
    Wild West
    VN-VS airbox isn't really ideal, I tried using one as a base and it just doesn't fit well, especially in a JDM car with the radiator overflow where it is. i did make a very crude fibreglass bottom mould of the wheel arch but rushed it and it didn't turn out that well.
    It's funny you started this thread Seamus as I've been thinking over the whole air box thing since the motor has been out. What I've come up with so far is making another fibreglass bottom for the wheel arch, use the cut bottom half of a VN-VS airbox, mount it upside down on a slight angle so that the filter is facing the hole behind the headlight. I've already got some ducting from the bottom of the bumper up behind the headlight to help with air flow.
    Ok
    Seamus
    Milton
    ^ That sounds pretty good timbo, but i'm wanting to make something blingy
    And others, sorry if there's some confusion - i just mean using literally *just* the panel filter - and make the airbox
    So i could have something "pretty" (it's just another excuse for me to get to do some welding heh).
    I was basically thinking of making EXACTLY this:
    But making it so it accepts a filter such as this:
    Anyone see a problem with that? Or maybe a better way of doing things? I'm open to any suggestions really
    ^ Clicky clicky!
    Michael
    Crimebrook 2749
    well jsut make something like that then........
    would be easier then making a complete box,
    Senior Member sotiros86's Avatar
    Andrew
    Wollongong
    I have one of the ARC units, and it is a very nice bit of gear, with welded bellmouths inside the box to provide smooth, even airflow.
    The only thing that im not really a fan of, is the fact that cold air isnt drawn into the filter, as there isnt much of a gap between the filter and the bonnet. I personally would like to see something which also incorporated a snorkel which drawers cold air from the front of the car.
    I like your idea of using a commodore filter, as they are available from almost everywhere, as speaking from experience, i can say that trying to find one to fit the ARC box is a pain in the ass.
    7OXIN, if you want some detailed pictures of the ARC item for reference, PM me, and ill send you some.
    Veteran johl's Avatar
    Johl
    Would it be better to have the filter panel underneath so the air is being drawn in from the front bar and up to the filter? I think there would be more airflow from underneath rather than on top. There is one for sale at the moment
    Andrew
    Wollongong
    The problem with putting the filter underneath is that you will end up drawing a lot of crap into the filter, which could include water, and the last thing that you would want is to suck up water.
    Veteran McLEVIN's Avatar
    Nov 2010
    arn't they designed to hold a specific volume of air, its not just simply making a box that'll fit?
    MOPAR or no car!
  1. Replies: 5
    Last Post: 20th November 2012, 12:48 PM
  2. Replies: 19
    Last Post: 27th June 2012, 10:12 PM
  3. Sprinter in ARC
    By Dom86 in forum Toyotas in the Media
    Last Post: 7th November 2011, 01:57 AM
  4. ARC. TOYOTA. TRD. NARDI. SPACERS. NOLTEC.
    By Wooley in forum Car Parts For Sale
    Last Post: 19th September 2007, 09:19 PM
