Results 1 to 8 of 8
Thread: please identify my zenki t series lsd
    Senior Member cooter's Avatar
    Sep 2010
    Craig
    Perth hills
    Default please identify my zenki t series lsd
    hey all
    im wondering if anyone can identify this lsd that came out of my te71 levin with a zenki t series disk diff.
    im leaning towards it being the oem lsd as it doesnt lock hard and has the old skool toyota symbol next to the OG but yeah just want confirmation. ive never seen a standard unit
    also sorry if this sounds a bit stupid but the gears running it are 8t pinion and 39t crown. that means 4.87:1 ratio yeah?
    cheers for any help
    craig
    Phirom
    Looks like a TRD one from what I remember, OEM ones have like a rounded corner inspection window.
    Also, I believe the crown wheel should have the ratio stamped on it somewhere on the side.
    Sep 2010
    Craig
    Perth hills
    yeah the crown has 8/39 stamped. id be pretty stoked if it was a trd unit cause it turns out the other trd unit ive got is a kouki. but this one looks nothing like the other
    Sep 2010
    Craig
    Perth hills
    just for arguments sake heres the other one. now bare in mind i dont know that this one is definately a trd unit as when i bought it i also got told its zenki but my axles are real loose in it but still go in. so i dont know whether to trust that info.
    craig
    Phirom
    My bad, I think I got that around the wrong way. The rounded window is the TRD and the one installed is the OEM unit.
    Edit. Yeah if the axles are real loose, it could be a kouki model. I got hit by the exact same thing a while back also.
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    Correct.
    First picture is an oem (rubbish) lsd, the trd 2way is the one you want.
    Make sure its not a kouki though if your diff is in fact a zenki
    Sep 2010
    Craig
    Perth hills
    yeah it is a kouki as ive had a bit of a look through the forums and the axle sizes are only slightly off which is why the axle is "loose" in the trd unit. just wanted to make sure it was also infact a trd unit
    dont spose anyone wants to buy a kouki trd lsd?? lol
    cheers for your help guys
    craig
    Veteran slydar's Avatar
    Dimitri
    its OEM. there are kits to overhaul/iprove them but its not really worth it these days. 2nd hand aftermarket LSDs are pretty cheap now.
    78's
  1. Wtb: Zenki t series 2 way lsd (small axle type)
    By TOY3TG in forum Cars or Parts Wanted
    Last Post: 20th July 2011, 05:10 PM
  2. SA: LSD Zenki centre to suit T Series, t18 diff
    By Patric in forum Car Parts For Sale
    Last Post: 1st June 2011, 06:58 PM
  3. WANT TO BUY: Zenki T-Series LSD
    By AE71 InSaNiTy in forum Cars or Parts Wanted
    Last Post: 1st November 2010, 07:07 PM
  4. QLD: Zenki LSD, 3 x zenki axles, zenki disc brakes + discs
    By FLT LNR in forum Car Parts For Sale
    Last Post: 28th August 2010, 07:12 PM
  5. Zenki Cusco RS 2way LSD + T-series + Tailshaft
    By sr20 trueno in forum Car Parts For Sale
    Last Post: 5th June 2008, 07:42 PM
