Results 11 to 20 of 21
Thread: 4k Battery/Alternator problems
    Davey & Riki-lee
    South Australia
    Seaford SA
    get some one who knows what they are doing to fix it.
    Our introduction - Click here
    8ball
    what he said.
    shit i must be an electrician cause i can use a multimeter, na dude its really not hat hard if its a dial multimeter turn it around til its on the 20v or the closest one to 20v (but not under 12). then use the black needle to earth it out the the red needle to what ever you are checking for a circuit.
    hopefully this helps
    Nathan
    Lilydale
    the wire pictured is for the supressor, all it does is reduce electrical 'noise' that can occur sometimes. it is not needed for the alternator to operate. (it does indeed connect to the 'B+' on the alternator.
    turn your ignition on, but do not start the engine, is the 'CHARGE'(or batttery symbol) light on your dash lit up?
    If it is lit up, does is turn off when the engine is started? because it should.
    it sounds like a wiring fault, in either the 'B+' wire to the battery + terminal, or the charge light wire isnt connected at the back of the alternator.(thin wire)
    hope this makes sense mate!
    Senior Member ke70 xx's Avatar
    Troy
    Woody
    Well I know for sure the battery is now busted so ill replace that again because i had the alternator tested by someone who knew what they were doing. I kinda learnt a few things.
    Quote Originally Posted by MINIHORSE View Post
    "if i ever get another 86 i think it will be a track only car"
    Tried that....failed.....you will too....its like sleeping next to a supermodel everynight and only getting to nail her 5 times a year
    Troy
    Woody
    Can anyone help me. Willing to pay. Went to an auto electrician and he didnt know shit from clay. Will go to different one if no one can help me. I need to get to work everyday and i barely am atm. Thanks for the help everyone. Keep the ideas coming. Going to try another alternator of a friends car and see if that works. Cheers Troy
    Senior Member 350hp4agte's Avatar
    underwood
    qld
    jimboomba
    were do you live dude
    Troy
    Woody
    I live at woodville. Can travel to peoples houses if they can fix it. But not keen to go to far because dont want battery dieing in middle of traffic.
    underwood
    qld
    jimboomba
    i have no idea were that is if you pull the altinator off the car it should have stamped on it B+ maybe S and w or something like that but either pull the altinator off and check let us no what it has on it or take it to a auto sparky i would help ya man but im in brissy and i assume your not
    Troy
    Woody
    Nah im in adelaide. I took it to an auto elec and he told me the b+ wasnt connected but it was a bracket but he insisted it was b+. Ill talke it to a different one tomoz i reckon.
  1. 4k - problems oil related
    By anastasios in forum Technical - Questions
    Last Post: 7th August 2009, 01:08 PM
  2. ke70 4k alternator.
    By Marco in forum Cars or Parts Wanted
    Last Post: 20th March 2009, 01:38 PM
  3. 4K Alternator
    By Andrew in forum Cars or Parts Wanted
    Last Post: 29th October 2007, 07:44 PM
  4. 4agze alternator dead or is battery too big to keep charge ?
    By kravit in forum Technical - Questions
    Last Post: 24th July 2007, 07:41 PM
