038 is white and 282 is an open diff (283 is the lsd)
Can someone please help me identify my ae86
Model code: E-AE86-ECMQF
colour: 038 white?
Trim: FM32
Trans: T50
Axel: T282 non LSD?
Plant: M21
Frame no: AE86-5043743
I thought it may have been a gtv but looking into a bit more it must be a gt? Just curious if it has the factory interior in it? Atm it has the red gtv interior.
MOPAR or no car!
get your chassis number will help you identify all the details etc.
Model code: E-AE86-ECMQF. E = Corolla Levin. C = coupe 3 door. M = 5-speed manual. Q = spec level, GT in this case. F = petrol EFI multivalve engine (4A-GE in this case).
colour: 038 = white
Trim: FM32 = red fabric
Trans: T50 = 5-speed split case
Axel: T282 = T series 6.7" diff, 4.3:1 ratio, 2 pinion open centre.
Plant: M21 = one of 2 different plants that made them, both in Japan.
Frame no: AE86-5043743 -this number can be used to find the build date, but I don't have the info in front of me.
So your car is a Levin GT 3 door. No LSD. Maybe drum brakes on rear.
Thanks very much for your help.
MOPAR or no car!
Should be a GTV as GT was only for 2dr body type. Check and see if you have the shorter P/S knuckles along with the narrower rack and thicker rear anti roll bar as these are all GTV specific (bar the P/S knuckles)
