Results 1 to 8 of 8
Thread: 212mm clutch question
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    Default 212mm clutch question
    hey guys and girls(unlikely haha), i have just got a 20v lightened flywheel for my 4agze.
    question is,
    i am getting an Excedy button clutch, what i need to know is do i order a clutch for a ae92 4age (smallport) or a ae101/111 20v (dont think it will really matter as they are bother 212mm clutches), and also most IMPORTANTLY, will the spline in the clutch disc for either of those fit a t50 input shaft?
    ~KEEP DRIFTING FUN~
    Aaron
    the spline will fit for both. the only difference when you order the clutches will be the throw out bearing.
    other than that the clutch kits are the same. aslong as they are the same size clutches.
    if you read an exedy book (or maybe the website) they break down the parts that you get in the kit. they also give you measurements on what splines the clutch disc has etc. the other cool thing about the exedy book ('07) is it has a picture of how not to bed your clutch in. the picture is ueo drifting in his 86
    they also tell you what spigot bearing your supposed to use.
    the only thing that gets me with exedy aus, is that you only get the plate, clutch and throwout bearing in the kit.
    all the exedy clutches i have gotten from america and japan come with the spigot bearing/bush and also a little plastic clutch aligning tool.
    Veteran timbo's Avatar
    Tim?
    Wild West
    Yeah the spline will fit, I just got a new 200mm clutch plate in my rebuild from NPC. Also have a clutch aligning tool if you want to borrow it Mereki.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    how do I get an exedy book?
    Aaron
    i got mine from a trade show. they were handing them out like candy.
    you could try emailing them
    Mark
    i ordered an ae93/ae92 with 4age kit then i asked them to swap the throwout for an ae71 one. This was at bursons and they were happy to do that!
    Senior Member Vaughn's Avatar
    Vaughn
    Sunshine Coast
    had the same problem with mine, i just went into car bitz and they sorted it all out
    Just another Muppet
    Endeavour Hills
    I will thanks
  1. 212mm flywheel and clutch
    By Nic19 in forum Car Parts For Sale
    Last Post: 12th December 2009, 09:59 AM
  2. clutch industries HD organic 212mm clutch
    Last Post: 10th December 2009, 04:09 PM
  3. WTB: 212mm Clutch and pressure plate
    By ae8zn6 in forum Cars or Parts Wanted
    Last Post: 25th November 2009, 08:46 AM
  4. ExedyHD 212mm clutch to suit 20v + flywheel
    By kaibeecee in forum Car Parts For Sale
    Last Post: 14th April 2009, 10:17 PM
  5. 212mm clutch +bigport +t50
    By shelldrake in forum Technical - Questions
    Last Post: 14th August 2006, 03:13 PM
