Hey guys, finally found a rod/piston package for my 4age but they sell it in 10.2:1 and 11.5:1 compression.. Really wish I could go the higher comp ratio but I have no idea what kinda compression you can run on 98 in a 16v.. if it helps my engine will run a 7rib with oil squirters, forged rods, forged pistons, with a 260º 8.4mm(PRETTY sure) cam set.. oh in a bigport head.
Really thinking I'll only be able to run the 10.2 comp pistons with like a 0.8mm head gasket, shave the head, deck the block.. etc, to get it to around 10.5~~
Any ideas? Wanting this to make as much power with this set up as possibly :/
