Results 1 to 10 of 11
Thread: measuring an fittings
    Glenn ke_70's Avatar
    Clay
    Barossa!
    Default measuring an fittings
    hi all quick one here
    what do i measure here to find out what size an fitting to get.
    do i measure the thread?
    Jul 2010
    Mat
    Christchurch
    Sydenham
    New Zealand
    the bore (hole up the middle) of it will tell what size of line its for and the fittings are the same an- number but it looks like an-3 to me is it turbo feed or brakes?
    Veteran Skylar's Avatar
    Ken
    -4 is 11mm OD at the outside of the threaded part.
    Looks like a -3.
    -3 AN flare bore size is 0.125", 0.171" for -4.
    Senior Member Dylan's Avatar
    Dylan
    Clay
    Barossa!
    the od of thew threaded part measured at 3/8''
    so it would be a -3 yes?
    its for brakelines
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    Yeah, its a -3.
    Those Earls fittings are a pain in the arse to get. Power brakes dont have any, and nor do Outlaws (at least on Friday). Andy has the part number at AutoSport and might be getting some in. Im waiting for them to come from a mate in Canberra atm
    Edit: are you getting rid of those to put AN lines in?
    Clay
    Barossa!
    they're for my hydro handbrake. basically im using my wilwood lines for the handbrake and want to piss off that 'pigtail' spec hardline and put a banjo fitting with an AN fitting to go straight on the end of the banjo.
    anyway i'll elaberate in my build thread
    Clay
    Barossa!
    thanks for the help too guys!
    Jul 2009
    Vic
    Ah, where did you get them? or did they come with the kit?
    Clay
    Barossa!
    i got them with the wilwood kit. i had braided lines for the front already so i used the wilwood lines for the handbrake and clutch line.
    have to tryed wilwood them selves? joel got me another set as the original one he sent were 3/8 instead of m10x1
  1. Bendix: Measuring a Brake Pad
    Last Post: 26th September 2011, 01:40 PM
  2. Measuring Coilover Ride Height
    By Dave in forum Technical - Questions
    Last Post: 1st February 2009, 01:10 PM
  3. oil cooler and fittings for sale
    By deanoo in forum Car Parts For Sale
    Last Post: 14th October 2007, 07:11 PM
  4. oil fittings
    By meadan in forum Technical - Questions
    Last Post: 4th October 2007, 04:10 PM
  5. Brake Fittings
    By jason in forum Technical - Questions
    Last Post: 4th September 2006, 10:01 PM
