Results 1 to 9 of 9
Thread: JDM rear caliper bleeder thread.
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    Default JDM rear caliper bleeder thread.
    Just trying to confirm the thread for the bleeders on JDM rear calipers.
    Reading its M7x1, anyone confirm?
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Yep, M7x1.0. Same as USDM calipers.
    Andrew
    Jul 2009
    Vic
    Ta, need to get some speed bleeders for them. Bleeding both front and rears at the same time on the pedal box is a PITA.
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Have you looked at the Earls 'Solo-Bleed'?
    I've been considering them instead of the Russel/SpeedBleeder ones, as they have a sealant that wears out after a few bleeds. Unlike the Earls design. I had an unused set of 4 Russel ones I sold because of this, but never bothered to get the earls ones..
    Andrew
    Jul 2009
    Vic
    The sealant on the threads? That shouldnt matter at all, the bleeder seats down against an internal convex seat, which does the sealing. The sealant is merely there so that you dont get any blowby of brake fluid via the threads (and suck in any air in reverse)
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Sorry, I wasn't clear. That's what I meant, the sealant wears out and causes it to suck in air past the threads when trying to bleed.
    Andrew
    Jul 2009
    Vic
    Yeah, that will always be a problem. Will even be a problem with the Earls type, especially if you are vac bleeding.
    Which by and by, works quite well:
    Veteran timbo's Avatar
    Tim?
    Wild West
    Haha that is an awesome way to bleed brakes! Looks like some sort of futuristic space bong though...
    Jul 2009
    Vic
    Heh, it actually sucks a whole bunch of air through the thread, which is why the other ones have sealant. Bit annoying, but it still works all the same.
  1. Parts for Rear JDM caliper rebuild!
    By haydenz in forum Technical - Questions
    Last Post: 25th August 2010, 12:57 AM
  2. JDM rear caliper problem
    Last Post: 10th June 2010, 11:39 PM
  3. JDM Rear Caliper rebuild kit
    By haydenz in forum Cars or Parts Wanted
    Last Post: 12th February 2010, 12:43 AM
  4. Left JDM rear caliper
    By MiC in forum Cars or Parts Wanted
    Last Post: 20th May 2007, 10:30 PM
  5. WTB JDM Rear Caliper Kits
    By ke25 racer in forum Cars or Parts Wanted
    Last Post: 18th March 2007, 09:46 PM
