Results 1 to 6 of 6
Thread: Ra40 axles in zenki t series diff
    Member Sprintn's Avatar
    Jul 2011
    aminos
    victoria
    west
    Default Ra40 axles in zenki t series diff
    Just wondering if anyone can tell me if celica ra40 axles will fit into my zenki t series diff, or even if the whole diff will bolt up... Thanks in advance..
    Mt Macedon
    Yes, RA40 axles fit (assuming it's a drum braked diff with the normal, not huge, wheel bearings). I can no longer remember if you have to cut 10mm off the end of each axle, but 30 seconds with a tape measure will tell you.
    And the whole diff will bolt up... to an RA40. But I guess you're wanting to put it in an AE86, in which case it can be made to fit, but isn't particularly easy (have a search about it).
    Jul 2011
    aminos
    victoria
    west
    Thank you very much, I think I read that 10mm has to be cut off the ra60's.... Would you also happen to know what gear ratio is in the zenki t series? I wanns know if it'd be worth putting in the ra40 diff as I only wanted to do it for the 4.1's lol
    West
    RA40 diff is not a bolt in, some people will tell you they have done it, but its not a good idea. One pair of mounts is correct, the other isnt, and the spring seats are mislocated, I've measured it all up before.
    Jul 2011
    aminos
    victoria
    west
    Oh ok fair enough, im putting a 4agze in my 86 this weekend and want something that will hold, hopefully the t series I have in atm will just need an axle which im getting but out of an ra40
    Mt Macedon
    You can pull the whole centre pumpkin thing out of the RA40 diff and put it in the zenki T series diff (which I assume you currently have in your car). And you then have whatever ratio RA40s run with. I think it's 4.1 for manuals at least, but you can look it up on Google or just count teeth/look for numbers stamped on the crown and pinion once you've got the centre out.
    RA60 axles definitely have to be trimmed 10mm, but I can't remember whether it is also true for RA40s. Easy to check though once you have the bits.
  1. Zenki T series axles [BRIS]
    By blair in forum Cars or Parts Wanted
    Last Post: 3rd August 2010, 08:37 PM
  2. WTB: Zenki Axles for T Series
    By civa in forum Cars or Parts Wanted
    Last Post: 16th July 2010, 08:05 PM
  3. T Series ae86 zenki and t18 axles
    By ae86 in forum Technical - Questions
    Last Post: 9th June 2010, 10:34 PM
  4. t-series axles or diffs. either ra40, ra60, t18 etc...
    By phil in forum Cars or Parts Wanted
    Last Post: 13th April 2009, 12:42 AM
  5. ra40 axles into t-series
    By eightsixboy in forum Technical - Questions
    Last Post: 6th July 2008, 10:22 PM
