I have one of these lying around doing nothing. Came out of my T18.
3tg hybrid
260 2tg head
Double valve springs
Reground cams
Ported head
Reseated & reground valves
New valve stem seals
Shaved head
New gaskets
3tc block crank & rods
Fly-cut 60 thou oversize 3tc pistons
Fully balanced bottom end
Twin 18rg solex carbs
4 into 1 extractors
2.5 inch straight through pipe
Electronic crane cams ignition
Lightened flywheel
Xtreme heavy duty clutch
T50 gearbox
Locked series 2 t-series diff
I want an easy bolt in job with not too many mods (ie custom mounts/crossmember etc)
Ideally wanted to put it all into a TE71 Liftback but they're rare as shit over here.
I think it would be easiest to bolt it into something that comes with a 3TC from factory. What cars are they apart from the T18?
Any idea/suggestions??
Thanks.
