ke70?![]()
I have one of these lying around doing nothing. Came out of my T18.
3tg hybrid
260 2tg head
Double valve springs
Reground cams
Ported head
Reseated & reground valves
New valve stem seals
Shaved head
New gaskets
3tc block crank & rods
Fly-cut 60 thou oversize 3tc pistons
Fully balanced bottom end
Twin 18rg solex carbs
4 into 1 extractors
2.5 inch straight through pipe
Electronic crane cams ignition
Lightened flywheel
Xtreme heavy duty clutch
T50 gearbox
Locked series 2 t-series diff
I want an easy bolt in job with not too many mods (ie custom mounts/crossmember etc)
Ideally wanted to put it all into a TE71 Liftback but they're rare as shit over here.
I think it would be easiest to bolt it into something that comes with a 3TC from factory. What cars are they apart from the T18?
Any idea/suggestions??
Thanks.
ke70?![]()
corona
ta22 celica
70's Celica.
Old corolla. Pretty sure you could find an appropriate crossmember somewhere.
KE20 Corolla. TE27s exist so you can use that crossmember*
* may or may not be extremely difficult to find.
sell it to me?
Didn't you guys (or was it the Swedes) have KE20's til 1987? Did that mean you also had TE27's? or was that a jap thing.
There was a xmember for sale in nz not long ago.
