Ok, getting very sick of destroying pads in a single weekend because of the massively uneven pad wear on the rear.
So looking at a brake upgrade for the JDM T-series diff.
I was hoping to use the R32 GTST calipers, but the piston depth is huge, and so its quite hard to fit under a lot of 0ish offset wheels.
What else is there out there that is twin opposing cylinders? Or is there a bolt up solution?
