yes.
they are the same 13/16th's master.
Car - 83 JDM Trueno Notch.
Motor - Bigport 4AGE.
Use - Project/Weekend toy.
Problem - Master is leaking.
Occurs/Started When - Since I noticed it.
Personal Situation (if applicable) - I'm rather short.
Hey guys, just a quick question. Will an ADM brake master cylinder fit my JDM Trueno?
I want to keep things standard so no cross breed master cylinder business please.
Thanks heaps, Dan.
yes.
Actually, probably no.
Check the bolt pattern first.....
Thanks for the info, but who's right?
Will an ADM fit my JDM? will the bolts and lines all line up correctly?
Cheers.
ADM is horizontal
JDM is usually on an incline
yep adm and jdm are not interchangable.
you can however just change to an adm brake booster.
