Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: 4agze into my ae86
    Member Sprintn's Avatar
    Jul 2011
    aminos
    victoria
    west
    Default 4agze into my ae86
    Hi all just wondering if anyone can tell me how hard its gonna be to put a 4agze engine in my 86, my 86 currently has the N/A 4age in it and i was told it will be simple, the guy i bought the engine off i also bought the 86 off him, he said he set up the 4agze to bolt straight and done all the hard work but never got around to putting it in, so now i just wanna confirm that.. Cheers in advanced
    Timmy D
    North
    you will need to turn the throttle body inlet 180deg (research changing to a 60mm as the standard 45mm is very restrictive at high rpm)
    custom out let for supercharger
    custom piping for front mount inter cooler (standard top mount is yucky)
    will need to lengthen the wiring loom
    sort out your water system, get a thermostat housing off a FWD 4age and adapt that to work
    the motor will bolt up to the standard t-50 gear box (get another t 50 as spare because you WILL brake it)
    standard engine mounts bolt up
    there is loads of info on doing this so punch it into google and start reading
    highly recommend 14psi pully, ecu and tune!
    good fun little motor, bulk toque down low and the super charger whine is a great sound i could never get enough of
    JJ
    Timmy D
    North
    JJ
    Moderator Sam-Q's Avatar
    Endeavour Hills
    this is the first time in quite a long while that someone has asked about 4agze conversion, the supply of them has really dried up so maybe that's why there is a lack of interest.
    Timmy D
    North
    Also need to cut of one corner/mounting hole on the supercharger bracket, as it will stop you from mounting the rwd engine mount.
    They are great but about as attractive as a baby sloth! When in rwd configuration
    You can try and make them look neat but there is just pipes and manifolds and brackets everywhere
    JJ
    Jul 2011
    aminos
    victoria
    west
    Sweet as hopefully it doesnt give is too much trouble...
    Jul 2011
    aminos
    victoria
    west
    Also can I use the loom off the 4age thats currently in there?
    Timmy D
    North
    no you will have to use the ze loom and lengthen it
    JJ
    Jul 2011
    aminos
    victoria
    west
    Ok thanks heaps
    Will
    Nairne
    It's a pretty simple swap really once you've got the supercharger outlet pointing the right way for your front mount, the wiring loom was pretty easy in my conversion but if you can afford it i'd deffinately look into an aftermarket ecu..
    Saves so much time!
  1. MELB: 4AGZE PACKAGE or 4AGZE + AE86
    By 1.6PWR in forum Car Parts For Sale
    Last Post: 7th May 2010, 05:40 PM
  2. F.S ae86 4agze
    By EZZE86 in forum Cars for Sale (Toyota Only)
    Last Post: 3rd October 2008, 12:54 AM
  3. 4agze ae86
    By DriftPlease in forum Cars for Sale (Toyota Only)
    Last Post: 22nd July 2008, 05:31 PM
  4. 4agze ae86
    By Ben Mr..hachiroku in forum AE86 Owners Forums
    Last Post: 13th December 2007, 08:00 PM
  5. 4agze into ae86
    By CHAMP in forum Technical - Questions
    Last Post: 29th May 2007, 10:40 PM
