you will need to turn the throttle body inlet 180deg (research changing to a 60mm as the standard 45mm is very restrictive at high rpm)
custom out let for supercharger
custom piping for front mount inter cooler (standard top mount is yucky)
will need to lengthen the wiring loom
sort out your water system, get a thermostat housing off a FWD 4age and adapt that to work
the motor will bolt up to the standard t-50 gear box (get another t 50 as spare because you WILL brake it)
standard engine mounts bolt up
there is loads of info on doing this so punch it into google and start reading
highly recommend 14psi pully, ecu and tune!
good fun little motor, bulk toque down low and the super charger whine is a great sound i could never get enough of
