Results 1 to 4 of 4
Thread: Water pipes and heater core question...
    Member stalker's Avatar
    Auckland
    Manurewa
    New Zealand
    Default Water pipes and heater core question...
    Hey all,
    Couldnt find the answer I was looking for (but I am blond, so may have missed it lol).
    What I am wanting to know is, can I plumb the water pipes direct from the engine straight into the heater core, then back out towards the radiator? Or does the heater core cause a blockage and wont allow the water to pump around the engine/radiator as it should and therefore overheat the engine?
    Ie. After putting the 7AGE into my levin we werent sure if having the coolant pipes coming straight out of the engine block and into the heater core, then back into the radiator plumbing would cause a restriction then cause cooling issues.
    We had thought about buying a "T" section and putting that into the pipes then it can just feed into the heater core without taking all the water and not causing a blockage (if thats what would happen), but its so cold here I want my heater now!!! lol.
    Hope im making sense....
    Mt Macedon
    I wouldn't run all my coolant through the heater core.
    1 - The heater core connections are much smaller than the rest of the cooling system, so you'd severely limit flow, making it more likely to overheat.
    2 - If you turned the heater control to cold then you'd stop all flow through your engine, overheating it.
    Run a proper water setup, there are plenty of photos around of how things are setup stock, and how they can be modified. Have a bit of a dig and you will find something you can use.
    Auckland
    Manurewa
    New Zealand
    Ahh true, good point, hadnt thought about the size of the pipes. Cheers.
    Would it make a difference that I have removed the part that controls the hot/cold of the heater unit? I mean the old vacum box that would send the hot water from the engine into the heater core when you turned the dial to hot. I was just thinking of running the heater unit on hot all the time lol.
    Cool cool, guess I cant get rungi on it and will have to do it the proper way hahah
    Thanx heaps
    Moderator Sam-Q's Avatar
    Endeavour Hills
    back of the engine to to heater tap to heater core out and to the bottom radiator hose connection on the remote thermostat or back of water pump
  1. heater core
    By pfrats in forum Technical - Questions
    Last Post: 22nd April 2012, 10:55 PM
  2. Heater Core
    By wartex11 in forum Cars or Parts Wanted
    Last Post: 13th July 2010, 12:18 PM
  3. WTB:[VIC] - AE71 heater core & Heater tap..
    By tc-rolla in forum Cars or Parts Wanted
    Last Post: 16th August 2009, 02:08 AM
  4. heater core
    By .ady in forum Technical - Questions
    Last Post: 7th July 2009, 05:59 PM
  5. ae86 heater core (heater box )
    By 131-sam in forum Cars or Parts Wanted
    Last Post: 28th March 2008, 04:24 PM
