Results 1 to 10 of 14
Thread: Haltech Guru's
    Senior Member JinxD's Avatar
    Ash
    Default Haltech Guru's
    Hey guys does anyone know of someone thats able to come have a look at my crap
    Problem ive got is that i cant get a "RPM HOME SIGNAL"
    ECU is a E6K running a blacktop 20v 7AGE
    any help appreciated
    GhettoGarage.org
    Quote Originally Posted by mild seven View Post
    i cant stand "JDM faggots" (people outside of japan who are MORE JDM than people in japan)
    Jun 2009
    Alex
    Valley View
    Running the stock dizzy? Optical wheel?? Have you checked the settings in the software? I'm wiring up an E6 at the moment so it's pretty similar.
    Ash
    Got it talking had the cas wired wrong, any ideas on base map figures? We have got it to the point of almost starting it's coughing and spluttering but not quite enough to maintain idle
    GhettoGarage.org
    Jun 2009
    Alex
    Valley View
    Is the Ignition timing still in safe mode? Do you have a 02 sensor? If ignition timing is still in safe mode it will be locked to 10 deg but that should still be good for idling.
    In terms of fuel maps maybe try richening up the figures till 1500rpm. Buutttttt....... I think you should maybe try the automap function to get it to idle. In the menu
    there should be an option that you select an rpm that you assume will give you peak torque and it should give you a good base map to start from.
    I'm no pro tuner so take my advice with a pinch of salt.
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    That running with you're dizzy or mine?
    Seeing as you (Twinky) are down the road literally, maybe pop past?
    Are the settings similar to those on the second page of this document?
    Not sure (assuming) the trigger settings must be setup in the Haltech.
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
    Jun 2009
    Alex
    Valley View
    E6K software, wiring, manual downloads:
    So I've had a bit of a play around with the E6K software and it does not seem to have a quickmap function. So throw the easy option out the window.
    Plenty of compensation maps though! Have you got a laptop to tune it? what software version do you have?
    Ash
    nah didnt end up using yours marko mine worked in the end.
    yea ive got a computer talking to it. using software version 6.34
    GhettoGarage.org
    Jun 2009
    Alex
    Valley View
    Any luck with this yet?
    Timmy D
    North
    fairly sure the coil packs are screwed,on the hunt for new ones soon
    JJ
    Member Shrek's Avatar
    May 2010
    Josh
    This car needs more go!
  1. wiring guru needed - 20v + adaptronic
    By NIZLAH in forum Brisbane & QLD Events and Discussion
    Last Post: 18th September 2012, 01:13 PM
  2. Calling All Tech Guru's.
    By HarlemSessions in forum Technical - Questions
    Last Post: 25th February 2009, 12:11 AM
  3. hey there, any ae86 guru out there
    By RolandGTV85 in forum General Topics (No Technical Questions)
    Last Post: 26th July 2006, 10:00 PM
