Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: **rare** cusco lower control arms with tension control rods and lower arm bar
    Member SSD20V's Avatar
    Telly
    Inner West
    Default **rare** cusco lower control arms with tension control rods and lower arm bar
    As title stae 1 x CUSCO LOWER CONTROL ARMS WITH TENSION CONTROL RODS AND LOWER ARM BAR
    Got these off Jay from Buddy parts a few years back never had a chance to fit to my car.recentlt sold car so have no use for em.Apart from the paint all the joints look like they are in perfect order.Perfect for that drify or track car.
    Dont miss out
    Asking same price as I paid for them $1000 plus postage.
    Located Dulwich Hill NSW
ID:	20887Click image for larger version.
ID:	20888Click image for larger version.
ID:	20889Click image for larger version.
ID:	20890Click image for larger version.
    Site Supporter Javal's Avatar
    Josho
    For those who haven't seen these before, they're fucking brilliant. By replacing the whole front suspension pickups for the radius rod / castor rod / z-bar and swaybar D-mount, they allow the swaybar to be dropped straight out without removing any other components. With the 'power brace', which looks to be included running between the two suspension pickups adding rigidity by relieving some of the stress off the lower radiator support as a structural component, there is a discernible difference in perceived front end 'flex'. As for everything else being rose jointed, well, that kind of helps too.
    Free bump.
    Member ONCHRG's Avatar
    Jun 2009
    Wyndham Vale
    I'll grab this.
    Pm me your bank details with a price for postage to 3024.
    Thanks
    Telly
    Inner West
    Ill PM you a price this arvo mate.
    Veteran slide86's Avatar
    Huw
    Hills
    Wow you don't see these come up to often, I have these in my car. I'd say there be less than 6 cars in aus running this front end.......
    Veteran AJPS's Avatar
    Lonsdale
    z bar - josh too much time at holdens! haha
    as for the caster rods - the pivot is still in factory position as it replaces the mount - not bolted to it like others
    Veteran shift_rook's Avatar
    SE Burbs
    if there's enough interest i can look into having these replicated properly using a quality manufacturer, anyone got some i can borrow so i can get some CAD drawing made up?
    Lonsdale
    ^ you can still buy them new
    SE Burbs
    ah cool, will leave it then
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Not a discussion thread, if you wanna talk about them there's a tech section.
  1. Lower control arm identification
    By ke_70_blue in forum Technical - Questions
    Last Post: 13th November 2012, 06:41 PM
  2. WTD: lower control arm!
    By sprintrphile in forum Cars or Parts Wanted
    Last Post: 18th August 2009, 09:50 PM
  3. lower control arm problems.
    By Trucka 115 in forum Technical - Questions
    Last Post: 25th September 2007, 12:43 PM
