Page 3 of 3 FirstFirst 1 2 3
Results 21 to 22 of 22
Thread: 4AGE possible sensor problem?
  1. #21
    Nick
    I know this is an old thread - Jaydos not sure if your problems are resolved yet.
    im in a similar boat, trying to get a 16v big port running after a long time off the road and I have the exact symptoms described. Usually a inlet or exhaust misfire on cold start, rough idle, give it a bit of gas, try a few times and eventually it runs smooth... once its warm seems to start fine. it's almost like a "frog in the throat", once cleared it feels good and idles well.
    So far I have replaced a fuel pump, coil, cap, rotor, leads and plugs. Have reset timing to factory. it usually starts OK when the TPS is disconnected.
    Unfortunately I dont have a working engine check light, there is a bit of damage on my ecu board where the W wire goes and i havent been able to get it to work. So i am in the dark just replacing bits one at a time. trying to get my hands on another ecu, TPS and MAP sensor.
    I know that doesnt help u at all but i've just been searching the forum and this thread describes my engines symptoms exactly.. i'll let u know how i go
  2. #22
    Nick
    OK it turns out I have a sticky lifter on the #4 inlet side valve that is staying open and after a bit of warming up it must loosen up. As far as i can tell all the fuel, ignition and sensors are OK. That explains the misfires. As I said the engine had sat a while and there is years of crusty oil build up in the valve train.
    I will try and remove it, hopefully i can get it out, and clean or replace the bucket.
  1. who can look at a 4age problem for me in the N/E
    By pnda86 in forum Melbourne & Vic Events and Discussion
    Last Post: 19th December 2010, 11:45 AM
  2. Throttle postion sensor problem -- ?
    By AIROCOBRA in forum Technical - Questions
    Last Post: 31st March 2010, 11:08 AM
  3. Brand New 4age Dizzy Cap & 4age Map Sensor
    By hugh in forum Car Parts For Sale
    Last Post: 14th September 2009, 10:22 AM
  4. wtb 4AGE Map sensor and throttle sensor
    By ae86driftstyle in forum Cars or Parts Wanted
    Last Post: 22nd March 2007, 08:35 PM
  5. will the o2 sensor fix my problem?
    By yoshimitsu9 in forum Technical - Questions
    Last Post: 25th November 2006, 11:02 AM
