Results 1 to 8 of 8
Thread: 4agze into ae86 wiring help
    Member Sprintn's Avatar
    Jul 2011
    aminos
    victoria
    west
    Default 4agze into ae86 wiring help
    Hey guys its been a week since I swapped engines over and still nothing has been done lol, if anyone could help in some way that would be good, or even if someone could recommend me where to go and get it done, thanks heaps in advance... Cheers
    Noooob
    You don't need 3 threads asking the same question in a different way....
    But as for your issue, I'd recommend ringing a few of the importers down there to see if they can recommend an Auto electrician for you.
    Veteran Skylar's Avatar
    Ken
    Ok, let's start with what diagrams/pinouts you're referring off, what you've done and what is working. What engine do you have?
    Jul 2011
    aminos
    victoria
    west
    I just done a 4agze conversion into my ae86, I followed a step by step DIY on club4ag, didnt get anything happening till today, got spark and power at the ignitors, CAS etc, fuel pump working also, car is cranking but wont start, the wiring loom that came with the 4agze was hacked so its been abit tricky, also my 86 was a 4age before this not a 4ac
    Ken
    You shouldn't have power at the CAS???
    How good is the spark?
    Timing gunned it?
    Fuel pressure?
    Jul 2011
    aminos
    victoria
    west
    Your right no power at CAS, and spark was pretty strong... As for timing and fuel pressure I havent checked, doesnt the car have to be running to timing gun it?
    Noooob
    Check power at the injectors and listen for your fuel pump.
    If you have spark, then it is reasonably safe to say the coil + ignitor / ecu are right.
    Jul 2011
    aminos
    victoria
    west
    The fuel pump is working, the Injectors I checked with a test light apparently I have to check injector pulse dunno how tho, yeh it has good spark thats good to know theyre right
  1. 4AGZE wiring question!
    By s3phro in forum Technical - Questions
    Last Post: 15th May 2011, 11:59 AM
  2. 4agze wiring and ECU
    By keiichi in forum Technical - Questions
    Last Post: 12th December 2010, 10:06 PM
  3. 4AGZE Wiring diagram
    By Wally332 in forum Technical - Questions
    Last Post: 19th April 2010, 01:07 AM
  4. 4agze wiring diagram
    By rundown in forum Technical - Questions
    Last Post: 27th October 2007, 10:36 PM
  5. Wiring on 4agze
    By AE86dori in forum Technical - Questions
    Last Post: 5th August 2006, 04:07 PM
