Results 1 to 5 of 5
Thread: What tie rods and rack ends to use on drift t18 setup - knuckles and 27mm lca
    andrew
    prospect
    Default What tie rods and rack ends to use on drift t18 setup - knuckles and 27mm lca
    hello,
    i have a T18 with the following setup
    -kelway drifto 0acerman knuckles
    - +27mm LCA
    -AE71 crossmember and rack
    -bolt on rack spacer and slip on spacer
    WTF tie rod ends and rack ends do i use?
    model numbers?
    please ... shit fk.. help me..
    thanks andy
    Site Supporter Javal's Avatar
    Josho
    AJPS motorsport tie rod tubes + ends
    Or Corona / Celica style double adjustables, if they go long enough.
    Infact just call Dave at AJPS. He'll have what you need on the shelf most likely.
    Veteran AJPS's Avatar
    Lonsdale
    yes they will work, yes I have some
    pm me
    thanks javal
    Lonsdale
    but hang on
    t18 is steering box and has dual adjustable stuff standard?
    Have you tried with the factory parts?
    andrew
    prospect
    we ended up using the standard t18 rack ends and ae71 tie rod ends with the t18 adjuster.
    have 10mm thread in both sides.
    ended up getting +25mm lca and kelway knuckles
    difference in car is amazing
    also for the tyre not to hit the firewall i need a rim with 7 +0 as minimum.
  1. Replies: 0
    Last Post: 5th March 2010, 06:59 PM
  2. tie rods ends and shit!
    Last Post: 5th September 2009, 11:53 AM
  3. tie rods and rack ends so expensive?
    By sundee in forum General Topics (No Technical Questions)
    Last Post: 21st February 2009, 11:30 PM
  4. WTB front short stroke shocks, tie rods & tie rod ends.
    By Ade_Mc in forum Cars or Parts Wanted
    Last Post: 24th October 2007, 11:58 PM
  5. Steering Lock - Quaife Rack, PS Arms, Tie Rods, Tie Rods Ends
    By SoKAR in forum Technical - Articles
    Last Post: 26th August 2007, 09:18 PM
