AJPS motorsport tie rod tubes + ends
Or Corona / Celica style double adjustables, if they go long enough.
Infact just call Dave at AJPS. He'll have what you need on the shelf most likely.
hello,
i have a T18 with the following setup
-kelway drifto 0acerman knuckles
- +27mm LCA
-AE71 crossmember and rack
-bolt on rack spacer and slip on spacer
WTF tie rod ends and rack ends do i use?
model numbers?
please ... shit fk.. help me..
thanks andy
yes they will work, yes I have some
pm me
thanks javal
but hang on
t18 is steering box and has dual adjustable stuff standard?
Have you tried with the factory parts?
we ended up using the standard t18 rack ends and ae71 tie rod ends with the t18 adjuster.
have 10mm thread in both sides.
ended up getting +25mm lca and kelway knuckles
difference in car is amazing
also for the tyre not to hit the firewall i need a rim with 7 +0 as minimum.
