Twin Thermo Fans from WRX Impreza STI 1999.
Condition: As new (out of a used car). Pics show a bit of dust, been kept on a shelf..
Description: Thinner than Falcon AU fans and just as good or better many have quoted as more powerful. Fans do separate, (don't have a joint shroud) but do bolt together/line up in two halves.
Price: $80 + Post or Pick-Up
Originally to be used on my set up but did't clear my air-con pulleys. Never been used at all since Ive had em.
These are not plastic, they are a type of thick nylon made material so it's very durable. The wiring seems to suggest the fans run at dual speeds, but you can wire up to single if you like. These were never used.
-- THUMBNAILS --
DIMENSIONS ARE:
(Measured per each fan / size of shroud is measured for total overall)
Height: 36.5cm
Width: 38.5cm
Depth: 8.5cm~ (at largest bulge of the fan piece shroud)
