Results 1 to 10 of 18
Thread: ae86 4age fuel line
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    Default ae86 4age fuel line
    hi, i have a quick question. When doing a 4age conversion in a ae86, would you need to upgrade the fuel lines if you are running a strong intank pump?
    Veteran shift_rook's Avatar
    SE Burbs
    yes 8mm lines needed, no matter how strong a pumpis with only 6mm lines you get massive friction loss
    Mt Macedon
    ^^ No. You can use the stock lines. I ran a 110rwkw 4AGZE for years through the stock lines (with VL pump). So they'll be fine for a 4AGE.
    Going to 8mm isn't a bad idea if you have big power plans, or need to replace the fuel lines anywya, but not necessarily required.
    Veteran Rice86's Avatar
    Richard
    Liverpool
    thats what i thought, so many people use standard 4ac fuel lines with no dramas...
    time to pile the car/s up and burn them all i think...enough headaches for a life time!! xD
    dose
    Phuoc
    Liverpool
    which line would be use for in, return and for charcoal canister
    Akio
    Mt Haruna
    Japan
    i fitted a new 8mm line works great.
    anyway, new line fuel forward to engine. original 4AC fuel line was now return, and the original canister line i didnt need to touch.
    Senior Member adam's Avatar
    Adam
    I'm currently using the standard feed as the feed, standard return as return and I haven't touched the breather line and it's running fine. Just replaced rubber hoses and clamps.
    Standard big port with extractors, exhaust and pod.
    Jason
    Southern Suburbs
    I have run 160rwkw 4AGTE on standard 4ac line but am going bigger. It did lean out towards the end. Also running original AE86 fuel pump in EFI tank.
    At 120rwkw you would want bigger lines be it 5/16 (8mm) or 3/8 to be safe.
    Phuoc
    Liverpool
    i ran a s15 before and now running a 7mgte at the moment. should i run a ae82 twin cam pump?
    Reeece
    Casula
    Is your motor flooding still whilst on idle ? then hard to crank over due to flooded engine ?
  1. NSW WTD ae86 gt fuel tank, pump and fuel line supply
    By smash in forum Cars or Parts Wanted
    Last Post: 2nd February 2012, 09:09 PM
  2. Fuel Line Help!
    By tc-rolla in forum Technical - Questions
    Last Post: 14th July 2010, 03:04 PM
  3. JDM Fuel line size
    By luke86 in forum Technical - Questions
    Last Post: 29th January 2010, 02:53 PM
  4. t18 fuel line and return fuel line
    By fozz in forum Cars or Parts Wanted
    Last Post: 23rd December 2007, 04:55 PM
  5. fs JDM fuel line
    By Selk in forum Car Parts For Sale
    Last Post: 18th February 2007, 03:33 PM
