Results 1 to 10 of 11
Thread: will a t18 diff fit a ke70 wagon
    Scammer, DO NOT BUY FROM ME!
    Default will a t18 diff fit a ke70 wagon
    will a t18 diff fit a ke70 wagon im new to leaf back end
    No.
    Not unless you cut off all mounts on both diffs and use the leaf fish plates on the T18 one.
    Its do-able yes, quite easy in fact. But to answer your question, it will not bolt up without lots of mods.
    wats a good diff up grade for leaf ass end
    You can modify most things to suit leafs.
    I was using a T series (same as a T18 diff) modifyed to suit leafs.
    Theres not going to be anything that bolts in except for a S series diff out of a KE/AE panno. But they will be hard to find, and not really much better.
    What engine/gear box does your car have? Because your borg warner diff will take some abuse.
    just 4k i wont a spool not realy a fan of weld diffs
    You realise a LSD for a T series will cost you a substantial amount of money? As in $1000 - $2000.
    For the price of welding rods and stock KE diff centers, I would be welding it up.
    u can get a spool for a t seis diff for 300
    Elite rthy's Avatar
    Leo
    Tulla
    couldn't u get a spool made for a borgy?
    in addition axels are all over the place for the borgy
    Kieran
    you could get an s-series out of a panelvan and that should bolt up, so long as you have the tail shaft to go with it. then you could weld it
    but then i suppose there is nothing stopping you welding what is in there
    Mark
    And hijack!!!
    Ok so i was going to start another thread but i figured this is close enough to what i want to know.
    I need to know whether a series two t18 diff bolts straight into an ae71.
    I've put a T series into an ae86 before with no worries but i want to make sure about this before i pull the diff out of my car.
    i'm running vl excel g's in the back, same as i was in the sprinter, and some ae86 king springs so that should be fine. I'm mostly just worried that the trailing arms or panhard won't fit!
    Oh and while i'm heading off topic i guess i'll ask my other question which is.....
    Will i have any problems putting a 22mm whiteline adjustable swaybar for an ae86 into the front of my ae71?? I already found that i had the wrong bushes for the rear so just want to make sure of the front.
    Mark
  1. Replies: 4
    Last Post: 29th January 2012, 09:13 PM
  2. T18 diff LSD problems, doesnt fit?!
    By drift kid in forum Technical - Questions
    Last Post: 4th October 2011, 08:46 PM
  3. will a ae71 diff fit in a ke70
    By Cyo18r in forum Technical - Questions
    Last Post: 23rd June 2010, 10:46 PM
  4. do t18 guards fit on to ke70 ?
    By ae71turbo in forum Adelaide & SA Events and Discussion
    Last Post: 9th May 2010, 08:00 PM
  5. WTB: Ke70 Wagon or T18
    By Beau in forum Cars or Parts Wanted
    Last Post: 10th February 2009, 06:04 PM
